MH 44-how to set up for antique tractor pulling
mhmalcolm
07-16-2006 04:26:42
I just purchased a Massey Harris 44 standard and am thinking about doing some antique pulling with it. I don't want to make any major changes to it but want to be competitive.The engine was overhauled not too many hours ago and it really runs sweet-no missing at all at high speed or idle and starts almost the instant you hit the starter button with no choking in 65 degree temps. Anybody have any tips on tweaking that I can do? I have a spare carburetor and could modify it. Any suggestions would be appreciated.
Ian Johnsen
07-16-2006 23:40:46
 Re: MH 44-how to set up for antique tractor pullin in reply to mhmalcolm, 07-16-2006 04:26:42
You could start with a Pertronix electronic ignition conversion. Maybe ditch running through the oil bath air cleaner and get a direct clamp on K&N air filter. Make some governor adjustments for more rpm. If you're just going to occasionally pull with it, and not work it, you could drain the old, thick gear oil in the gear box and run hydraulic tractor fluid and less of it for less drag on internals. Every liitle bit helps.
