Farmall M
Kevin
07-15-2006 16:05:00
Is a 4.310x6 a strong div 2 set up for a farmall M? I am curently looking at a stuck M. Is it alright to start with a stuck tractor when doing a project like this or will i run into more problems than its worth? Im just thinking it will be alot cheaper if i start stuck but i could be wrong. I never built a motor myself, will this one be easy enough for me to learn on? Im curently looking at dennys kit wich retails for $1995. Is this a decent price? I realize it wont be 120hp like they claim as i understand they are cheaters over at dennys, wich bring me to another question, who makes a kit comparable to this one at a comparable or better price?
Thanks for any help.
Flogger
07-17-2006 13:32:04
 Re: Farmall M in reply to Kevin, 07-15-2006 16:05:00
If it's an M block (248 cid) I'd go 4.25 X 6.5 and I'd get the block checked for thickness at that. Plenty of machine shops can stroke the crank and you can go 6.5 about as cheap as 6. You're going to have do a little clearancing at 6 anyway so go ahead to 6.5. JE's can make you a set of pistons for about $600. With a good head and everything else optomized you'll be all over 100 hp at stock rpms.
The lady who answers the phone at Denny's has a bad day every one in a while...
Kevin
07-16-2006 10:38:26
I understand everyones different opinions on dennys but your comment dont help me much. Any one able to answer my questions?
newpuller
07-17-2006 08:26:28
 Re: Farmall M in reply to Kevin, 07-16-2006 10:38:26
There are quite a few of guys who use that set up. I personnally do not. I probably would have done that if I could afford it. And like he said do buy from Denny's it ain't worth the trouble. Contact Chad at the tractor shop, Tractorshop.com
Chad is ChadS who posts on this website. They can get you a similar set up, if not the exact one.
newpuller
07-17-2006 08:18:34
Don L C
07-15-2006 17:35:48
Want some good advice????
Stay away from Denny's !!!
