Need quik help on 44 rpm adj
Kevin
07-14-2006 14:21:51
I am in knee deep with my 44 and need some help adjusting the rpm. I tried just about everything i could think of and cant seem to change it. It runs 1000rpm idle and 1650 wide open. I want it to run alittle slower on idle. Seems like no matter what i do to bring idle down it brings down the high idle too. Then i make a counter adjustment with the gov. screw to bring high idle up and low idle comes back with it. I have a pull tommorow and need some help. I even tried the idle screw on the carb and i didnt have much luck. Any help is apreciated. Thanks.
slowsmoke
07-15-2006 04:24:31
 Re: Need quik help on 44 rpm adj in reply to Kevin, 07-14-2006 14:21:51
Check the length of the rod between the gov. linkage and the carb. might be a govenor weight stuck. good luck
