more rpms
newmpuller
07-13-2006 14:07:39
How can I get some more rpms out of my M.
newpuller
07-13-2006 16:18:42
 Re: more rpms in reply to newmpuller, 07-13-2006 14:07:39
Two easy adjustment will do it if you haven't done them already. Open your governor access plate. Where the spring goes toward the front of the motor is an adjustment screw (lower one ther are two), back it out until there aren't any threads showing. Then take your hood off. On your throttle rod, where the pivot is mounted on your head, you'll see two springs. The front one has a nut in front of it. back that nut off until you have about 5 threads showing. Then open your throttle all the way and watch the lever on the govenor where the throttle linkage attaches. Ideally you want that to bottom out on the engine block. If it doesn't back the nut on the throttle linkage off some more until it does. By doing this, what you are doing is adjusting the most amount of throttle movement you can get. Once you make these adjustments close the govenor up and start up the motor. Open the throttle slowly all the way, after it warms a little, you will have to hold it because it will go past the last locking point. If the motor surges at all then replace the spring in the govenor. I did this and I didn't have to replace the spring. We ran it on the dyno at 72 hp with 281 cid kit. The govenor kicked in and held the ponies there. Try it, it works.
buickanddeere
07-13-2006 14:58:31
Rememeber centrifcal and reciprocating forces increase at the power of 2 with relation to rpms. Flywheels etc have been torn off tractors before.
MDOG
07-13-2006 14:16:17
Go to your local hardware store with your spring. Find one with 2 or 3 less coils and same diameter wire. Costs about 2 bucks, not 20.
