venturi in carb
slow mo 57
07-12-2006 08:50:25
Will a smaller venturi make d17 engine lug better.I have a bigger one in my zenith than stock.I 50 HP wc on tight dyno.It just dont lug on a good POWER track!!! Help please thanks
ES
07-12-2006 18:36:25
 Re: venturi in carb in reply to slow mo 57, 07-12-2006 08:50:25
put a vacum gage onit that will tell you if you are to big or to small
Jerry/MT
07-12-2006 17:48:35
If you increase the venturi size you need to put in a bigger main jet since for the same full throttle rpm, the delta P across the main jet is less so you get a lower fuel/air ratio i.e yu'll run lean.
slow mo57
07-13-2006 07:53:17
 Re: venturi in carb in reply to Jerry/MT, 07-12-2006 17:48:35
I put a bigger jet at same time as venturi.Every thing looks good at exaust pipe.Under load on the track and off.I am going to try Vac gauge.I have been try to make it work on the track.
champspa
07-12-2006 17:28:56
go back to a stock size and see if it costs you to much on the top end , then see if you can lug the sled further, you pull a sled not a dyno.
