Big Lick/CATPA start time pulling order?
Flogger
07-11-2006 08:39:26
Does anybody have the start time of the saturday CATPA pull at Big Lick and the order the classes will be pulled?
JDRooster
07-11-2006 12:55:16
 Re: Big Lick/CATPA start time pulling order? in reply to Flogger, 07-11-2006 08:39:26
Flogger, I will send you a personal flier tomorrow via the "Topper".
Flogger
07-11-2006 13:02:44
 Re: Big Lick/CATPA start time pulling order? in reply to JDRooster, 07-11-2006 12:55:16
Was just thinking about you 'rooster. Need the 'topper's assitance on a little job and he said I should ask you first....
Da Bulldog
07-11-2006 10:50:49
Flogger - check out>Link
MAYBE>Link it's correct although it's a little hard to read. May see you there
Flogger
07-11-2006 12:09:43
 Re: Big Lick/CATPA start time pulling order? in reply to Da Bulldog, 07-11-2006 10:50:49
Found it, and thank you maam... Hope to make it to a pull ot two down your way sometime this season if my work schedule will ever cooperate.
jd b puller
07-11-2006 12:08:30
This seems to be a "southern" thing. Why is it that a lot of the pulls in the south, they jarble the classes up like that? I'm used to "high to low" or "low to high". I know for me it's tough, cuz the kids aren't old enuf to hang around all day.
Flogger
07-11-2006 12:13:42
 Re: Big Lick/CATPA start time pulling order? in reply to jd b puller, 07-11-2006 12:08:30
I think in a lot of cases if you're pulling 9000 and 10000 they will make them far enough apart to give you time to get it weighed up. Same with 5 and 6000, 3 and 4000 etc. 'Takes this old boy a few minutes to hang or pull off a 1000 lbs.
