Turbo on a MF 97
Kevin
07-10-2006 08:00:54
I took my MF 97 to a farmstock pull yesterday and didnt do as good as i was hoping. Seems like almost 99% of these farstock tractors are all turbo. That brings me to my question. What are some basic general farmstock rules? Seems like there are never any posted at these pulls. Could i add a turbo to my 97 and still be farmstock? Couldnt i say it was a field modification to get better fuel mialege and more power? It still could pass as a farm tractor. Before i jump off the deep end what can i do to pump this beast up without adding a turbo. I plan on having about $2000 to play with. Its deffinatly got the cubes there with the moline 504 6cyl, so can a natrually aspirated diesel be cranked without breaking the bank or killing the tractor? The tractor does run real smooth and i dont believe there are any major internal problems as of now.
Ian Johnsen
07-12-2006 20:24:59
 Re: Turbo on a MF 97 in reply to Kevin, 07-10-2006 08:00:54
Our club (PSATMA), in Washington state, has a farm stock class where we are able to run a turbo up to T04 on tractors not originally equipped with one. It must fit under the stock sheet metal. You can also increase the pulling RPMs to 3500. Speed limit is 12 mph. I believe the term farm stock was confusing to some , so we have changed it to hot farm.
MM705 puller
07-10-2006 10:41:54
The rules change through various clubs so there is no saying what is farmstock and what isnt where you pull. I pulled a 705 with a 504 in a naturally aspirated class. I had a standyne pump on it with a 45mm head and also did the injectors. It ran well with other naturally aspirated tractors. We were able to get plenty of fuel to it but couldnt get enough air to the poor head design and being indirect injected. If you added a turbo you would probably be able to get the air that we didnt have. The pump and injectors would take most of your $2000. We decided to get rid of the diesel and go to a gas because of easier horse power and being cheaper to build. You can build the diesel but will take some money. With the cam thats in those 504's you will never be able to run over 2500rpm. So if you really want to have a a good running 504 be prepared to spend some money.
