Stoneys reschedule G.V.A.T.C
Kevin
07-05-2006 07:16:50
As far as i understand the are rescheduling this pull for sunday. Am i the only one that has a problem with this? I also pull a 10,500 farmstock massey 97 and there is a pull in east concord running 10,500-16,500 on sunday. Now i dont want to miss any points pulls with the 44 becuase i took 1st place last pull with this new set of tires and if i keep it up i might have a chance. But...that big ol 97 doesnt get to pull much, only 3 or 4 times a year.
oliver 1900
07-07-2006 06:27:24
 Re: Stoneys reschedule G.V.A.T.C in reply to Kevin, 07-05-2006 07:16:50
Where is east concord??
CLIFF S
07-05-2006 19:32:09
Hey Kevin, Did you ever get any G.V.A.T.C Rules? Do they Pull Cut Tires or Non Cut tires? Or Both? How Big of tires from 3000 to 4500 ? Whats there Hitch limits heigh and long ? Is there a Speed Limit ? Thanks Cliff
Kevin
07-06-2006 11:34:37
 Re: Stoneys reschedule G.V.A.T.C in reply to CLIFF S , 07-05-2006 19:32:09
What division would you run? Div II (3mph) Div II+ (5mph) or Div IV (open)? Let me know and i will type up the rules.
CLIFF S
07-06-2006 15:53:51
 Re: Stoneys reschedule G.V.A.T.C in reply to Kevin, 07-06-2006 11:34:37
We are from Central PA and here we pull Top Cut tires 3.5 mph And new tire 3.5 mph And theres a guy that can run open class that may come! Is your divions like NATPA Rules? I have a Div 3 and Div 2 tractors Under there rules! Any Help would be Appreated!
Kevin
07-06-2006 20:47:33
 Re: Stoneys reschedule G.V.A.T.C in reply to CLIFF S, 07-06-2006 15:53:51
Ill have the rules up tommorow, they are out in the truck right now. Im going to say come on up and pull, we can probly fit you in somewere even if its just exhibition. We are pretty close to NATPA rules except for a few small thing like div II and II+ need stock air cleaner in tact and working. 2 and 2+ are allowed top cuts, 4 is full cut. I will get all the rules up that you need tommorow.
Kevin
07-07-2006 19:54:24
 Re: Stoneys reschedule G.V.A.T.C in reply to Kevin, 07-06-2006 20:47:33
Div II(3mph) and II+(5mph) 3000-13.6x38
3500-13.6x38
4000-13.6x38
4500-15.5x38
drawbar-no closer than 18inches from center of rear axel no higher than 18" from pulling surface.
no stripping to make weight classes, no aluminum or plastic, must use stock air cleaner, 10%rpm, no visual engine modifications
Div IV(let er rip)
3500-7500 18.4x38
drawbar-no closer than 18 no higher than 20
Must use stock manifold, kill switches and side panels, 20%over rpm
Let me know what tractors you got and i will let you know what the lowest class is you can pull in.
CLIFF S
07-08-2006 05:44:27
 Re: Stoneys reschedule G.V.A.T.C in reply to Kevin, 07-07-2006 19:54:24
I have a Super C and there is a guy with a DC Case and a Guy with a Allis WC, Thanks Cliff
CLIFF S
07-08-2006 05:46:53
 Re: Stoneys reschedule G.V.A.T.C in reply to CLIFF S, 07-08-2006 05:44:27
Also is there any weight allance?
Kevin
07-08-2006 11:52:06
 Re: Stoneys reschedule G.V.A.T.C in reply to CLIFF S, 07-08-2006 05:46:53
What division will wich ones be running in?
You are alowed 200lbs for driver.
Do you need any directions for how to get there?
CLIFF S
07-08-2006 20:08:55
 Re: Stoneys reschedule G.V.A.T.C in reply to Kevin, 07-08-2006 11:52:06
Div 2 3mph and where kont sure yet if where going to go or knot yet What Time dose it start? we got directions
