Hey Chad S
MAGMAN
07-05-2006 04:51:50
Hi Chad, Everyone talks about watching the heat of a new motor. I have a gauge that reads # degrees not the Farmall style cold,Run, Hot, She seems to be wanting to run about 195 to 200 right now. The plugs are burning good brown a little black on a couple. Is that too hot and if it is what can I do. When I put it together I did not have a thernmastat that would fit and ruined the old one taking it out so It is without at this point. JON
ChadS
07-05-2006 05:18:02
 Re: Hey Chad S in reply to MAGMAN, 07-05-2006 04:51:50
New engines will run warmer for a while till they break in,,, Alot of friction is created with new parts until they establish the wear pattern to seat and seal properly. Friction = heat. 195-200 is OK, much over that is not,,, I was thinking the stock thermostat is rated for 190 degrees. Engines without a thermostat can fluctuate engine temps,, but usually IH's wont run hot if the fuel is set correctly to help keep it cooler,, Chad
