Oliver 70 build up
paul in iowa
07-03-2006 14:16:47
I am going to be building a oliver 70 for pulling I want to go with a 3.5 bore and 5.5 stroke and some major head work what kind of hp can I expect to get from this combo I want to get 100hp plus if possible thanks
Bryce
07-03-2006 16:01:07
 Re: Oliver 70 build up in reply to paul in iowa, 07-03-2006 14:16:47
Don't waste the time or money.You can gat more out of a 77 for less,I know ,I built a 70.There is just not enough room in those little continental engines.BUT if you must do it you can fit 3 9/16 in them but it is tight.
paul in iowa
07-03-2006 16:04:19
 Re: Oliver 70 build up in reply to Bryce, 07-03-2006 16:01:07
How much hp did you end up with thanks
Bryce
07-03-2006 17:08:10
 Re: Oliver 70 build up in reply to paul in iowa, 07-03-2006 16:04:19
62 at stock rpm on the pto.
James Tierney
07-05-2006 12:03:47
 Re: Oliver 70 build up in reply to Bryce, 07-03-2006 17:08:10
How long is the stroke on your 70 with 62 HP? I have a 3.445 bore x 5.5 motor I am hoping to have done soon.
Bryce
07-05-2006 23:45:47
 Re: Oliver 70 build up in reply to James Tierney, 07-05-2006 12:03:47
5.375 x 3.5625 But I am telling you if you have not done it yet the 77 is the way to go.I have spent far less and wound up 100 ci bigger and that was becuase I decided to stop not because I had to as with the 70 motor ,there is just not enough room either in the block or the head.Good luck whatever you do. Bryce
