IH560 standard/wheatland
toolz
07-02-2006 13:02:58
Just bought a 560 diesel standard, and would like to do a little local antique pulling. The tractor is stock, and has been in a barn for many years. It runs and sounds great. I changed all the fluids and filters, and will replace the tires. Anything I should check or look for? The rear tires are 18.4-30's, and I have a bad rim. I need one if anyone has a source. It's 16" wide, cast iron center. Any help would be appreciated. I'm new to this stuff. Thanks- toolz
DEARLY
07-02-2006 15:47:59
 Re: IH560 standard/wheatland in reply to toolz, 07-02-2006 13:02:58
GOOD CHOICE MY BROTHER HAD A 560 DIESEL MAN DID IT RUN WHAT CLASSES U WANNA RUN IF GOING LITE PUT SET 18 4 38 ON NARROW FRONT END U GAN GET IT TO THE 7000 CLASS ALSO TURBO ON IT GIVE U MORE POWER AND BOOST
toolz
07-02-2006 18:31:40
 Re: IH560 standard/wheatland in reply to DEARLY, 07-02-2006 15:47:59
Thanks for the reply- I really don't know about class. I just plan on playing at some local homecomings and such. Could lead to more- who knows.
Since this is a wheatland configuration, a narrow front is not an option. It has a low slung non-adjustable kinda wide front. The rears are 30", and I'll stay with the 18.4-30's. There's no weights on it, but it seems like it is at least 7000#, but the fluid will come out of the rears this week when the tires go on. Thanks again for the reply. KB
