clutch
tazfarmer460
06-28-2006 02:55:12
I'm wanting to put in a clutch that is a little better than stock. Is there any where they can change springs in pressure plate? Any thoughts on where to look. Its for a Farmall 460. Thanks.
Sweeper
06-28-2006 20:05:08
 Re: clutch in reply to tazfarmer460, 06-28-2006 02:55:12
Had mine done by Laycook in Memphis 7 years ago and had no trouble.
ChadS
06-28-2006 05:55:30
Just about any clutch shop can install heavier springs in a pressure plate, recondition it, and make a button clutch disk that can hold up to alot of abuse. I got a pressure plate from an old forklift (460) Had 4 more springs on the pressure plate than what the row crop used. Ive yet to slip it. Fort Wayne Clutch, in Fort Wayne,Indiana is the place to go around here. Hope this helps,
tazfarmer460
06-29-2006 19:18:11
 Re: clutch in reply to ChadS, 06-28-2006 05:55:30
Thanks for the info. I thought about taking the pressure plate apart myself and finding someone to test the tension on the springs but still don't know how much heavier to go. Sound like a good idea or should I let the pros do it. Thanks
ChadS
07-03-2006 07:13:29
 Re: clutch in reply to tazfarmer460, 06-29-2006 19:18:11
Id let them do it,,, yeah, you could put shims under the springs, or install heavier springs,, but if you cant reassemble it safely, its a bomb waiting to explode! Those pressure plates are not that expensive to buy, and have modified by a good shop. JMHO,,Chad
