FARMALL M
DEARLY
06-24-2006 02:57:37
PUTTING TOGETHER A PULLING TRACTOR USING STOCK GOV WHAT CAN I DO TO IT . GET MORE OUT OF IT ALSO NEED TO MAKE A KILL SWICTH FOR IT
newpuller
06-26-2006 12:42:46
 Re: FARMALL M in reply to DEARLY, 06-24-2006 02:57:37
I just ran my M on a dyno. The gov kicked in and held the HP there extremely well so I didn't have to do anything to the gov. But, you can safety wire a couple of the coils together, on each side of the spring, or just get a stronger spring.
TurboS10
06-24-2006 20:40:13
A 4 prong trailer socket works well for a kill switch. Simply loop the main switch wire through it so it will break the circuit. Just mount the female on the tractor and use a bolt with a washer welded on it for the male end. You will want to grind off the tab that holds it in so it will pull out.
