pulls in Illinois
Lenny Kirby
06-21-2006 11:07:17
Is there any pulls this weekend in Central Illinois... I know about the USAP pull down in Bonnie.. But with work I don't have enough time to get there... Preferably on Suday... We got our other F-30 going and would like to try it out before the points pulls start... any ideas? preferably Sunday... Thanks!!!!
Shawn W
06-22-2006 17:27:22
 Re: pulls in Illinois in reply to Lenny Kirby, 06-21-2006 11:07:17
Hello.
what are the rules and weight classes for the rankin pull on the 30th, would be intrested in coming up if i can pull with 18.4 tires, around 6500 lbs
thanks Shawn
Jerry Thomas
06-22-2006 13:40:01
Martinsville has a pull on the first of july and Casey has a pull on the fourth.
Travis M
06-22-2006 15:15:56
 Re: pulls in Illinois in reply to Jerry Thomas, 06-22-2006 13:40:01
What are the rules for Martinsville and casey. I would like to come out and try some new competition if my tractor is legal. Thanks Travis
Shawn W
06-22-2006 17:37:37
 Re: pulls in Illinois in reply to Travis M, 06-22-2006 15:15:56
Hello
hope this helps you out
Martinsville pull saturady 1st at 9 am
4000, 5500, 8500, modified stock 3.5 mph 18.4 tires 20%over rpm
super farm stock 6500 3mph 15.5 tires uncut 18 inch drawbar
5500 pro stock-open 18.4 tires 20% over on rpm, 20 inch drawbar
12500 farm stock anything goes, far from stock
Casey july 4th at 1 pm
has a class for everybody, basic usap rules only 15.5 tires in modified class and 18 inch drawbar in farm class, still have 18.4 in open class.
classes from 3750 to 12500
hope that works
Shawn
Lenny Kirby
06-22-2006 14:59:25
Hopefully it will be in the paint shop directly after Rankin... But maybe I can talk the old man into the 4th at Casey since I won't be around on the 1st or 2nd...(anniversary) I have been to Casy once it was a pretty decent pull not set up for the ITPA tractor but the other one should be ok...
Lenny Kirby
06-22-2006 10:51:17
Our first ITPA points hook is the 10th at Nashville. I'll have wheel speed of around 8mph.. so I should be going close to that... I wasn't at Lincoln last year it was probably my dad.. We were broke last year..(no. 3 rod=ventilation of block) Rankin has a pull on June 30 that we plan to have both of them at.. (other one isn't ITPA legal)
farmallguy46
06-21-2006 17:15:26
is your first pull on the 10th or 11th? one sheet has the 2 switched i beleive.i think i talked to ya at lincoln last year. im looking for all the pulls i can find also, not many around with the 4th weekend coming up. how fast will your f-30 make it down the track? everyone around this way likes there speed limits.my first points is fri night, only got 3 hooks on a soft track with it, so itll be interesting. ill let ya know if i find any.
g/l
