Govenor spring Super c
Kidd
06-20-2006 05:32:54
Instead of ordering a stock govenor spring I would like a little stiffer one . Does anyone know what I need to buy and where I can get it. Example length width and thickness. Next, should I change that little bearing on the govenor shaft at the same time as the spring? I'm going to be pulling in a stock 3500 class with 110 psi stock compression. What gear do you pull in 1st or 2nd. Thanks Kidd
Shaggy
06-20-2006 21:30:08
 Re: Govenor spring Super c in reply to Kidd, 06-20-2006 05:32:54
You could get one for a C-153 motor that came in a 303 or a 203 combine. Its a little shorter and a lot stiffer!
