mw governor for 560?
jpl
06-19-2006 13:30:00
Is there a m&w gov made for a 560 gas? or where can I get a spring to work or what. set my rpm to 2100 but will only still pull at 1800. thanks for any help.
M repair
06-22-2006 05:26:35
 Re: mw governor for 560? in reply to jpl, 06-19-2006 13:30:00
Grind off half the weights,,, or find governor weights from a IH C-200 ci gas engine. You can find this engine in IH 574 tractors, and power units, some ingersol-rand air compressors. Its a 4 cyl version of the 6 cyl,,, you will have to change the carb jetting to get the full potential,,, instant throttle responce!!!!
ejr-IA.
06-20-2006 11:22:01
Try to find a governor and spring off a 715 combine 301 or a 806,856 gas tractor that will wake it up.
jpl
06-19-2006 17:38:51
thanks for help, but you must be thinking of h or m, the 560 is different, the spring is outside and the governor doesnt have a side plate, I;ll get a manuel that maybe can show me. must be the linkage you adjust for rpm.
LumbrJakMan
06-19-2006 15:09:16
Set Throttle handle to lowest speed. Open Governor cover side plate. Wire the spring shut in 2 spots 180 Degrees from each other. Close Governor side cover , GO HAVE FUN !!
