Putting DLTX 71 nozzel in a 72 all fuel
JD 37 A puller
06-18-2006 09:43:04
First off can you do this, and besides the nozzel what is the diff. Does this make the all-fuel carb into a gas carb. Also how much hp do you get with the 71 over the 72.
Lynard
06-18-2006 16:17:39
 Re: Putting DLTX 71 nozzel in a 72 all fuel in reply to JD 37 A puller, 06-18-2006 09:43:04
JD 37 A The nozzle will interchange. All the nozzle does is accumulate fuel so when the throttle valve is suddenly opened extra fuel enters the motor. Changing this will not make a 72 the same as a 71 as fuel idle passages are different and the 72 has a fuel economizer plug. There will be no hp gain as they are the same size. Lynn
