Weight of items on an H Farmall?
migraine
06-16-2006 08:41:30
Trying to get 1940 H Farmall into 3500 lb class with 200 pound dirver. Am at 4000 now and want to remove belt pelley drive, pto and shield and belly pump and drawbar assembly and make a small custom hitch. Can I make it with these items or will I have to go to pressed wheels on front and back. Just wondering if someone knows what these items weigh? Thanks Migraine
Ken B
06-18-2006 05:40:44
 Re: Weight of items on an H Farmall? in reply to migraine, 06-16-2006 08:41:30
I have mine down to around 3700 with out me still have the old hitch ,wheels amd wheel bars (that are over built)3500 can be done ease Ken
cpoosch
06-17-2006 17:59:17
We run a Super H here that is just as you describe doing only it has pressed steel rears with 15.5 - 38 rubber. The rear seat is fabbed with square tube pipe. The tractor scales at 3720 with no weights and me in the seat (I weigh 175lbs.) I think it could be down to 3500 easily with pressed steel fronts, weld on hubs and cutting down the axles.
Good luck with it.
CP
AC
06-17-2006 04:44:16
Get some f12 cutoffs and you are in. I have W-4 axle housings for sale if you want any. You save about 30 lbs.
1066
06-22-2006 04:54:56
 Re: Weight of items on an H Farmall? in reply to AC, 06-17-2006 04:44:16
AC,I like your axle housings from W-4 for H and F-12 cutoff wheels.Phone # Thanks
MJF
06-16-2006 23:41:09
Build a frontend, you'll loose a lot there
virgils
06-16-2006 16:29:36
My 130 pound brother pulled my H last year at 3500 we has it stripped down to even taking the battery out of it to make it to 3500
migraine
06-18-2006 18:29:09
 Re: Weight of items on an H Farmall? in reply to virgils, 06-16-2006 16:29:36
Thanks for the help and ideas. I will go to work and see where we can go down to. I have a single front with pressed wheel which should help out also. What 9 bolt hubs will work on an H from other brands? Thanks Migraine
