Farmall M custom frontend
MJF
06-15-2006 19:14:42
We are going to build one here in the next couple weeks for my M. What do I need to build it. Tractor Supply 5 lug hubs right? what else Thanks a bunch
Turbos10
06-17-2006 19:14:34
 Re: Farmall M custom frontend in reply to MJF, 06-15-2006 19:14:42
I have seen them done different ways. Steering is best with a rack and pinion from a small junk car.
As for the bib parts, I am planning to use a cotten trailer front axle and narrow it down to fit. It has everything you need and has the angles already set up. All you have to do is narrow it. I have seen others made from jeep front axles, but they dont look as good IMO. The nicest have been from a cut down massey front end. It was completely reworked to look more low profile and to be more lightweight, but it looks very nice.
in
06-15-2006 19:23:33
Go to junk yard and find GM front wheel drive car , get stubs off back wheels, get two spares , lots lighter, tube and a couple of plates, start welding.
Drew
06-15-2006 19:45:55
 Re: Farmall M custom frontend in reply to in, 06-15-2006 19:23:33
I've used those before, worked very well!!
