Need some info from the experts for farmall M
jerm
06-14-2006 13:16:22
I need some advice from the experts I had a farmall M built 4 years ago and not to happy with the results can't complain because I did the work but now I want more power o.k. here it is crank stock cam stock motor has 450 pistions in it so yes it was bored the head was a stock head not sure on number of head but it was ported and polished again nothing really done head was shaved 90 thousands so my question is what can I do to get more horse with my budget only being 2000 dollars any help would be great you can also email me Thanks Jeremy
jerm
06-15-2006 14:39:19
 Re: Need some info from the experts for farmall M in reply to jerm, 06-14-2006 13:16:22
the carb and governor are stock I've only pulled this tractor 5 times in four years it sits the rest I'm just tring to get input on how much it would take to get 100-160 if not more horses out of it 2000 is what I have saved now. I won't be starting the project until winter but will pull it one or two times yet this year. I do thank you for your time and help so far it is much need.Also what division does most of the farmall m run??? I'm looking to division 5 but not with the m I'm thinking 460 or 560. First though how much does it cost to build or buy a division 5 tractor. I was going to build my 1206 for hot farm but too much money to run with the 66's and so on so looking to build my m and a division 5 tractor any more info would be great like to know the facts before I get started with project.Thanks again Jeremy
farmallguy46
06-15-2006 15:33:05
 Re: Need some info from the experts for farmall M in reply to jerm, 06-15-2006 14:39:19
theres a huge difference between 100 and 160hp...if you run stk block run div.3 untill you have enough horse to pull 4th or overdrive gears down the track.....for 160hp+ you'll need to save a few more years....15000+ for div 4 or 5 alot of work involved when you go over 500 cubes..if you build a big one watch it on the dyno, pto is built like crap..100 hp will break them...get an idea where your going to pull and build your tractor around them rules..they vary greatly..g/l
jhb
06-15-2006 04:44:29
You have not mentioned the governor. Should get about 63 - 65 hp from your setup but carburetor and governor proper setup can make all the difference. Just my free opinion, take it for what you paid.
B Barenie
06-14-2006 17:11:37
I have a set of pistons, setting at gary bakers, up in Michigan, his number is 734-678-9688 !
Piston's are set up for 4.125 bore by 5.75 stroke ! Product is awesome, price is rite, product may have been sold by now, worth the phone call. !
Bottom line ----- More horse power can be created by increasing cubic inch. Forget the fancy stuff.
Quality crank rods and pistons will do most of the work, an 8060d head will make do ! Because the tractor turns such low rpm's concentrate all your money in the short block ! Compression is extremely important, but on a small build-up, it doesn't come into play !
Get outside your club and find real information !
My 2 cents worth !
Drew
06-14-2006 21:06:20
 Re: Need some info from the experts for farmall M in reply to B Barenie, 06-14-2006 17:11:37
Cubic inches do no good if you cant feed them. Why not have a more efficient, smaller engine than a big engine that is very inefficient? You may very well have an awesome short block, but if you cant get air into it, it is pointless.
Camshafts, rocker arms, carburetors, manifolds, air intake tubes/filter system and cylinder head work ALL make horsepower.
B Barenie
06-18-2006 00:55:45
 Re: Drew-follow-up in reply to Drew, 06-14-2006 21:06:20
Drew:
In my neck of the woods, their are a couple of division (3) molines running. The first tractor built my merfield, absolutely nothing fancy, 585 cubes on propane , 4210 heads, stock manifolds.
The second tractor 545 cubes, built by marlatt,Tractor is on gas, expensive heads, manifold work and big truck carb, high compression, both tractors, very close at 540 on dyno in total h.p. out-put !
I understand carb airflo exctra, but on an m, from
321 to 370ci do all the tricks make that much difference ?
farmallguy46
06-15-2006 03:58:57
 Re: Need some info from the experts for farmall M in reply to Drew, 06-14-2006 21:06:20
well,drew, if we were talking 350 chevy's, or any cross flow head id agree. but even if he wasted 2000 on a lp head, roller rockers and a cam. he might squeeze 80-90 hp out of his 264cu motor, and be maxed out,(next step still needing 2000 more) with a 340 cu setup he would be making well over the 264's maxed out numbers, and could spend 500 next year and gain 10+ more with r.r., etc... id call baker, buy one of his carb's that he rec. with the 4.125 setup...he does very good carb work.i have 2 of them myself.youll be alot happier i feel 4.125's alittle small but still in the right direction, that way you dont have to buy rods and would need minimal clearance work on the block...
farmallguy46
06-14-2006 15:29:14
well, if time isnt an issue,and your alittle flex. on your budget...theres still guys doing cranks for $1000-1200..6 or 6.25...if 6 your could get a set of raised pin pistons from ross, 4.25 or 4.35 if youd choose to rebore, check your block out. prob. 500-600 now, the way things have went up. which head did you have? the 8060 has more use as a boat anchor but ya might be able to use it for now.a cam would be a plus ..couple hundro...by the time you add gaskets, block work,etc. itd push alittle over 2 but not too bad...4.25x6 would yield ya 340, 4.35x 6=357...id stay away from the low return stuff, like roller rockers and stuff till ya have more dough....that would prob fill your hp void for awhile...
