14.9 tires - shorter than 38
mshultz
06-14-2006 11:13:24
I'm currently running 16.9 x 24 tires on a case C. I bought it that way, and it pulls pretty decent. Later this summer I will have a problem pulling a few places though, so I need to work on a different set-up eventually. Some rules read that you can go 13.6 x 38 or one size wider if you go shorter - So I'm looking for a tire that is 14.9 x ???? Is there such thing as a 14.9 x 34, or anything else between 24" & 34"? What were they on from factory - would like to know which junkyards to check out.
Thanks!
06-15-2006 23:44:37
 Re: 14.9 tires - shorter than 38 in reply to mshultz, 06-14-2006 11:13:24
I`m thinking f-20 wheels will interchange with your c if they are the same as a cc case,I like my 14x36 wards on mine, I can pull in the 4,ooo class.
Jim in OH
06-14-2006 12:32:19
Add to that list 34", 38" and 42".. Here are the sizes available from Firestone. the number to the right is the "Flat Plate Area" in square inches that is sometimes used to define the allowable tire size in the rules.��Generally speaking, larger diameter tires pull better, but there are exceptions... Jim
Tire size Area 8.3-24�� 63
��9.5-24�� 79
��9.5-24�� 79
��11.2-24�� 96
��11.2-24�� 96
��12.4-24�� 119
��12.4-24�� 119
��13.6-24�� 130
��13.6-24�� 130
��14.9-24�� 160
��14.9-24�� 160
��16.9-24�� 196
��13.6-26�� 141
��14.9-26�� 166
��16.9-26�� 206
��18.4-26�� 242
��18.4-26�� 242
��18.4-26�� 242
��12.4-28�� 126
��12.4-28�� 126
��13.6-28�� 145
��13.6-28�� 145
��14.9-28�� 170
��14.9-28�� 170
��14.9-28�� 170
��16.9-28�� 209
��16.9-28�� 209
��18.4-28�� 250
��16.9-30�� 216
��16.9-30�� 216
��18.4-30�� 258
��18.4-30�� 258
��23.1-30�� 383
��23.1-30�� 383
��16.9-34�� 229
��16.9-34�� 229
��18.4-34�� 284
��18.4-34�� 284
��9.5-36�� 95
��13.6-38�� 168
��13.6-38�� 168
��14.9-38�� 200
��14.9-38�� 200
��15.5-38�� 189
��15.5-38�� 189
��16.9-38�� 252
��16.9-38�� 252
��18.4-38�� 300
��18.4-38�� 300
��20.8-38�� 352
��9.5-42�� 100
��12.4-42�� 150
dej(JED)
06-14-2006 11:21:42
There are 26", 28", 30" and 32" tires currently being used on tractors. A 14.9 and a 16.9 tire are of pretty much the same height. I don't know what configuration of a wheel you have, so it is difficult to offer suggestions. Often wheels will interchange from one tractor to another. There are open center rims, 8 bolt hole tin rims,9 bolt hole tin rims, 10 bolt hole tin rims and even 6 bolt hole rims. I hope this adds to the confusion, but seriously I might be able to steer you in a direction, but I am not familiar with a Case C.
