skipin moline
moli
06-12-2006 13:27:12
I just got the new headgaskets back on and retorqed down to 175 ft lbs after warm up...Then i went to my second pull and had no problems with head gaskets but....she breaks up under a load.Iput new distributer bushings in top n bottom,nice n snug...points are set at .o20 and plugs at set at.025..The valves are set at cam grinders specs of .o20 exh and .o18 int hot..I even chacked the float setting and its fine..I can get rid of this breaking up..Goin down the road in 5th at half throttle and nailin it makes her skip( break up)Ive been running cold autolites and 112 octane fuel at 195 psi per cyl.Advancing or retarding dist dont do nothin...GOT any ideas? I just sent for a petronics ignition today matbe that will do it....Any ideas would help....THANX
too hot
06-14-2006 06:14:22
 Re: skipin moline in reply to moli, 06-12-2006 13:27:12
valves too tite 28 ex 26 in.
Drew
06-13-2006 06:20:09
It almost sounds to me like it may be running lean if you nail the throttle and it pops and cracks.
Captainhookerus
06-12-2006 21:19:32
I finally had to use a pertronics plus a 6A MSD box, with a MSD coil. This seems to work with heavy plug wires and a good dis cap. If I had to do it over I would convert a noncomputer HEI distributer.
minnieub
06-14-2006 14:47:20
 Re: skipin moline in reply to Captainhookerus, 06-12-2006 21:19:32
That cured ours also. A petronics plus 6AMSD box.
Mopar-Harris
06-13-2006 05:14:08
Just out of curiousity, what is the advantage on the "noncomputerized HEI"?
SSB
06-13-2006 16:28:29
 Re: skipin moline in reply to Mopar-Harris, 06-13-2006 05:14:08
I'd say about 500 bucks still left in your pocket.
