valve adjustment on a G with rockers.
G-Money
06-11-2006 13:54:56
is the valve adjustment on a john deere g with roller rockers the same as stock
Drew
06-11-2006 20:23:39
 Re: valve adjustment on a G with rockers. in reply to G-Money, 06-11-2006 13:54:56
Start out with what your cam card says. Put the tractor on a dyno, and then play with the lash. I would start with loosening the exh. lash some. Im guessing the tractor and dyno will like it.
G-Money
06-12-2006 16:57:29
 Re: valve adjustment on a G with rockers. in reply to Drew, 06-11-2006 20:23:39
the cam is out of a 720 john deere.
Drew
06-14-2006 10:01:49
 Re: valve adjustment on a G with rockers. in reply to G-Money, 06-12-2006 16:57:29
In that case I would start with the Deere spec. for a 720 and work from there. Valve lash is a tuning tool. You are going to have to dyno the thing and see what it likes best, and that is different for every tractor.
When adjusting and dyno tuning, only change either the exhaust or the intake at a time. If you do both at the same time, you are introducing too many variables into the equation and will learn nothing.
OU812
06-11-2006 19:22:48
check your cam specs.
