Power block positive ID
wunderin
06-08-2006 21:02:47
Please help me positivly ID a power block in a styled B thats a running tractor. I suspect someone has taken a grinder to the lettering cast into it. This other wise stock looking b sees to have the power of a late A or maybe a G. Its a real power house "stock" tractor. Im justa wunderin.??? Thanks for the help!
WTW
06-09-2006 09:19:41
 Re: Power block positive ID in reply to wunderin, 06-08-2006 21:02:47
A Tractor Supply model B Power-Block does not look like any stock B block on the outside. If you are familiar what a model 50 stock block looks like the B Power-Block will resemble it. They both have the larger bulging water jacket just behind the head. The Power-Block was painted new Yellow, scratch off the green to see if it yellow underneath. Power-Blocks never had compression releases, if your block has them or plugs underneath for them it is not a Power-Block. To grind the Power-Block markings off the B model block it would be difficult without leaving allot of evidence as the room on top to do that would be limited. DW
Mike n Mo
06-09-2006 05:41:17
Look on the bottom of the block for the JD casting number, should start with B. If it's there, it's definately a Deere block. If no casting number, that lends itself to your theory about the power block lettering being ground off. Mike
730-LP
06-09-2006 04:36:21
No plugs in the bottom of the block to put in petcocks in any power blocks
Drew
06-08-2006 21:07:22
If you run out of other options, you can take a sparkplug out and shine a flashlight in the hole. Look and see if the bore is straight all the way up or if it necks down at the top.
