Secrets for Super C pulling
Kidd
06-06-2006 23:16:34
I just bought a super C and would like to know how to get the most power out of it . Espesially the govenor. It was as easy as a govenor spring for my super h what is it for the super c? I have 110 psi in all four cylinders, what is stock, what are the gaps etc. valves,points I also have brand new 11.2 feild and road tireson it, I plan on running it in the 3500 lbs class any help would be appreciated Kidd
family tradition
06-07-2006 12:29:18
 Re: Secrets for Super C pulling in reply to Kidd, 06-06-2006 23:16:34
I have a 153 I wanna sell, if interested e-mail me. I have not had it running but it is not locked up and is complete
CLIFF S
06-07-2006 04:21:45
Start With a Stiffer Gov Spring! Your Compression is Stock with Flait top Pistons! A 3 1/4 oversize Kit will Greatly Help your Power out with an Extra 5 HP if Set it up properly! Valves are set at .014 HOT and Point Gap Is .020, I would try to get it in 3000lb Class if you can, Then move into 3500lb Class.
Kidd
06-07-2006 07:20:58
 Re: Secrets for Super C pulling in reply to CLIFF S, 06-07-2006 04:21:45
So 110 is stockand where do I get a stiffer spring and how stiff. Will that give me higher rpm.
Kidd
06-07-2006 07:25:11
 Re: Secrets for Super C pulling in reply to Kidd, 06-07-2006 07:20:58
Sorry how do I get the most rpm out of it?
Kidd
06-07-2006 07:28:07
 Re: Secrets for Super C pulling in reply to Kidd, 06-07-2006 07:25:11
Someone told me that a combine motor will bolt right in, super c block with h bore and stroke. Do you know anything about that.
CLIFF S
06-07-2006 14:21:31
 Re: Secrets for Super C pulling in reply to Kidd, 06-07-2006 07:28:07
Well Kidd the way i see it is The Combine C-153 Will bolt in with some Work BUT you now have a Super C that some places won't let pull in stock type classes ans Shouldn't! The stiffer Gov spring will make it respond better and some time Setting it up on a Dyno after you made you Valve and points settings adjusting the Dist will yeald you some hidden HP!
Sleddog
06-07-2006 09:07:36
The c113-c123-c135-c146-c153 are based on the same block (series). However the front of the engine (waterpump), and the pilot bushing are different. If you want to change the block have some metalworking tools handy.
supermpuller
06-07-2006 11:44:06
 Re: Secrets for Super C pulling in reply to Sleddog, 06-07-2006 09:07:36
You need the 153 combine block, bolt in and hang on.
Shaggy are you hearing th
06-07-2006 16:30:13
 Re: Secrets for Super C pulling in reply to supermpuller, 06-07-2006 11:44:06
There are lots of Super C stock pullers out there that have combine motors...HMMMM?
Shaggy
06-07-2006 21:20:34
 Re: Secrets for Super C pulling in reply to Shaggy are you hearing th, 06-07-2006 16:30:13
I hear you loud and clear!! I am still looking for tire for mine but it has a few other bugs I need to work on. I am shooting for next summer to have a little fun with it!
