Massey 44 Diet
Kevin
06-01-2006 12:48:39
third party image
My massey 44 currently weights about 4400-4500lbs with no weights on it. I would like to loose some weight and preferbly id like to loose the weight for up front as in 4500lb class the front gets alittle light but would be nice for alittle lighter.
Here is a picture, see if you can spot anything that can go or if you even think of anything let me know.
JD hauler
06-01-2006 13:03:06
 Re: Massey 44 Diet in reply to Kevin, 06-01-2006 12:48:39
Yes ditch the pto if you can, most clubs want it in place for div 1 and 2, you might be able to drain out some rear end grease. I would stay away from buying anything from denny's , Get a one wire GM alternator from your local shop, they can set it up that way for you, does you tractor have the lighter nine bolt centers? there are thinner and thicker ones, to save money you could have some circles cut out of the centers (even light ones) to get rid of weight, maybe see about some 4 ply tires, go with 4.00 x 15's up front if you dont already. you could get rid of the main battery altogether and use a motorcycle battery or lawn battery, and build a jumper pack or get one from walmart to start up on, then you still have enough juice for ignition and lights , ditch the lights if you dont need those, I like to keep lights for those night pulls for loading and such. hope this can help you.
Kevin
06-01-2006 15:07:57
 Re: Massey 44 Diet in reply to JD hauler, 06-01-2006 13:03:06
Them are 4x12 4 ply fronts. Lights are already gone. Already have a gm alternator, would it be worth it to lighten the rear rims if im just going to put more weights on the back then? I am running this in div 2+ so the pto may be alittle risky but maybe worth it. Never even thought about a motorcylce battery, might do that for alittle loss of weight.
Kevin
06-01-2006 12:54:40
Sorry forgot to say one thing, what do you think about moving the battery to behind the seat and taking the pto out? It will remove weight from the rear but also transfer some weight back. Another thing i was looking at was a mini alternator from dennys that only weighs 5-1/2 lbs but that would cost me $200. I was looking at an electric fan but im not sure how i would work that with the water pump being on the same shaft. I was thinking of an aluminum front weight bracket but im not sure were to get on of them welded up. Give me some of your thoughts.
