Weight reduction
Tyler
03-30-2002 18:31:59
I have a 1951 U moline and it weighs in at 5420 with no one on it. I need some help with some ideas on how to make it lighter. I'm wanting to put it in the 5000# class.
U dude
04-01-2002 08:58:01
 Re: weight reduction in reply to Tyler, 03-30-2002 18:31:59
put on a fiberglass oil pan and top case cover available for around $300 youll lose 150 lbs.
BUD BARENIE
04-03-2002 04:33:46
 Re: Re: weight reduction in reply to U dude, 04-01-2002 08:58:01
i'm pulling a super m. is their a top plate cover
and oil pan made out of lighter material for the
farmalls. need to loose 500lbs need advice
tractor already gutted of the extra's weighting
5050lbs empty
pulling in stock class, can run pressed wheels
andy
03-31-2002 07:13:28
Loose the fenders,(block your seat post so it can't swing into the tires!), pto, hydraulic, pressed rims, lights, anything that isn't nescesary.
wendel
03-30-2002 19:08:59
Put some pressed steel wheels on it.Ought to get you nearly there.
Slo
03-30-2002 20:27:32
 Re: Re: weight reduction in reply to wendel, 03-30-2002 19:08:59
Try to lose it off the front. My U doesn't like anything under 6000. Too nose heavy.
Tyler
03-31-2002 10:28:42
 Re: Re: Re: weight reduction in reply to Slo, 03-30-2002 20:27:32
Thanks for the suggestions,but it has pressed steel rims already on it. No pto,fenders,ect. I was thinking about putting a uts front end on it, I don't know what the weight difference would be.
Shawn
03-31-2002 15:23:27
 Re: Re: Re: Re: weight reduction in reply to Tyler, 03-31-2002 10:28:42
Hello,
If your U has pressed steel wheels and weighs 5420, you have to have something else on your tractor your not telling us, maybe fluid in tires, wheel weights in front wheels? maybe a loader on the front?.
My U weighs 5320 with cast iron wheels, weight brackets and wheelie bars, no pto, no hydralics, no fenders.
If you put the standard front under it it should be heavier then the narrow front?
Sorry buts thats all i can help you
Shawn
yler
03-31-2002 16:12:33
 Re: Re: Re: Re: Re: weight reduction in reply to Shawn, 03-31-2002 15:23:27
Thanks, no fluid or wheel weights. The tractor has 800 jugs and heads. If you would like you could look at the tractor in the Jan. Hook Magizine or pull it up on there web site. It is on page 23. It has 18.4-38 tires and 18 inch rims. Everyone that has looked at the tractor can't believe that it weighs so much. One person has even told us that moline came out with a U one year that had a thicker rear end casting. I don't know. Any help would be appreciated.
Shawn
03-31-2002 18:48:39
 Re: Re: Re: Re: Re: Re: weight reduction in reply to yler, 03-31-2002 16:12:33
Hello,
Well i looked at the picture, sharp looking tractor, i dont have a clue why your tractor is so heavy, i do know U rear ends are heavier then UB rear ends, my tractor is a 52 and it had the live power, you can take that out and turn the gear around on the 2 shafts and weld it up solid, that will loose about 100 pounds, are those 18.4 X 38's they will ad up the weight also but i dont know how much.
thats my only clue good luck
Shawn
Wendel Welch
04-01-2002 19:12:34
 Re: Re: Re: Re: Re: Re: Re: weight reduction in reply to Shawn, 03-31-2002 18:48:39
I think that UTS axles & axle housings are lighter but you'll have to change hubs.
Tyler
03-31-2002 19:10:54
Yes they are 18.4-38 tires. What I'm wanting to do is us a uts front end and then make my own axle out of aluminum. Do you know of a front 5 bolt hub that would fit on the factory moline spindle? THANKS
