C 281 in a 350 Farmall
350 puller
05-31-2006 15:48:16
Will a C281 out of a 450 fit a 350? I know I will probably have to use the 350 flywheel and clutch, but will it fit between the frame rails?
If you have done it how much grief did you catch trying to pull it in your organization? whichever club it may be !!!!!
Pull by the rules
06-01-2006 12:28:31
 Re: C 281 in a 350 Farmall in reply to 350 puller, 05-31-2006 15:48:16
You could run it in Tunica and get away with it, they never check our tractor.
350 puller
06-01-2006 15:37:41
 Re: C 281 in a 350 Farmall in reply to Pull by the rules, 06-01-2006 12:28:31
I'll remember when I watch you pull in Tunica. I'll make sure you get inspected.
Dave in MN
05-31-2006 20:11:00
alot of work wasted if the pulls have a "stock block only" rule.
P.S. This will only be a problem if you win.
Prolly Not
05-31-2006 15:55:18
I'm sure it could be done one way or another but its not going to fit in the frame rails and it will be to tall for the hood... I'm more than positive it can't be done to look anywhere close to factory...
