How To Make Tire's Soft For Pulling??
Jim Luck
05-31-2006 13:30:39
Hey Guys & Gals; A buddy of mine has two Cockshutt Brand 1953 tractors that he uses for local tractor pulls!. This coming Saturday he will be doing his second local pull this summer and asked me the following question, and I told him I was ask my friends here for some advice or help of any sort!.
How can the large old tractor tires be made softer for better traction on asphalt?. These are almost stock tractors, but he still spin's the tires at the end of the pull, any extra traction would help!. He lost a 1st place pull 2 weeks ago by only 16", bummer!.
He know's you can buy expensive race car type compounds that you paint on. BUT, it is to expensive for his 5-8 times a year use. Does anyone have any idea's of something that could be used to soften these large old tires?. THANKS ALL!!...
buickanddeere
05-31-2006 21:21:16
 Re: How To Make Tire's Soft For Pulling?? in reply to Jim Luck, 05-31-2006 13:30:39
Some folks swear by ordinary chlorine fabric bleach? The shorter the tread bars the better on asphalt
b barenie
05-31-2006 19:43:44
apply heavy grease, let it sit for two weeks.
Pure mess, but it will tear up the rubber !
Agent Orange
05-31-2006 17:32:29
I have heard that WD40 will do the trick. Don't know how much but some of my GoCart budies have used it successfully. Don't know why anyone wants to pull on pavement.
newpuller
05-31-2006 14:55:22
Worn tires that are sharp on the front edges are best. Tire pressure is a biggie also.
One way to verify tire pressure is to look into the whole when you pull out. If the hole is rounded like a spoon you have too much tire pressure. You want the edges of the hole to be flat, square.
buckmaster 700
05-31-2006 14:30:08
you want your tires hard. the probem may be air pressure or he may have too tall of lugs making a pile of dirt infront of the sled or they cut in too deep i wouldnt waste money on tire compound . get a hand held electric wood plane and shorten the lugs or get some well road wore tires
Mike n Mo
05-31-2006 15:25:07
 Re: How To Make Tire's Soft For Pulling?? in reply to buckmaster 700, 05-31-2006 14:30:08
Re-read the origional post carefully! He said he"s pulling on asphalt.
Tire man
06-01-2006 13:24:28
 Re: How To Make Tire's Soft For Pulling?? in reply to Mike n Mo, 05-31-2006 15:25:07
VHT makes tire softner that is used on drag tires and they also make softner for sprint car tires too. Look thru Jegs of any dirt track racing mag. You should be able to find what you want.
