Weld on hubs
Kevin
05-31-2006 12:54:54
Were can I get a set of weld on hubs for my JD 60. I will be pulling 7500, 8500, 9500, 10,500 and UNL with a set of top cut 18.4x38 on heavy 9 bolt rims. Right now i have a set of the early light cast iron hubs but i would like to put a set of 20" wide rims on with the new 18.4 tires.
jd b puller
05-31-2006 18:59:54
 Re: Weld on hubs in reply to Kevin, 05-31-2006 12:54:54
Call me crazy, but why are you trying to save 100 pounds on a tractor that's got over 2500# of movable weight on it in the 7500# class? Or are you putting all the weight on the front already and can't keep it down?
Kevin
06-01-2006 04:19:24
 Re: Weld on hubs in reply to jd b puller, 05-31-2006 18:59:54
Im not trying to save weight although i relize i will be saving weight. Im just trying to find the easiest way to get 20" wide rims on it for the new 18.4 x 38 im buying, the tires come with a set of 20" wide 9 bolt rims so i feel im best of going for a set of weld ons. Unless there is a different hub that will fit it?
Mike n Mo
06-01-2006 07:35:10
 Re: Weld on hubs in reply to Kevin, 06-01-2006 04:19:24
I THINK the axle size is the same as a 4010 (measure 1st) so if you can find duel hubs for that they should bolt on. Another option is to get a pair of double bevel 18" wide rims (made for 20.8X38'S) and put the tires on them, use the cast centers and sell the 20" wide pressed steel wheels. I realize that involves changing the tires over, but properly welding on hubs takes time also. I have 18.4's on both 18 and 20" rims, and I think I prefer the 18's. Mike
jd b puller
06-01-2006 20:47:57
 Re: Weld on hubs in reply to Mike n Mo, 06-01-2006 07:35:10
I was thinking the same thing Mike. Pretty sure we put hubs from a 4010 on our 70 a while back. I remember having to make an adaptor plate though. Can't remember if our wheels weren't 9 bolt or the 4010 hubs aren't 9 bolt...
Dave in MN
05-31-2006 20:17:31
 Re: Weld on hubs in reply to IHpuller450, 05-31-2006 15:02:27
Dave Brugger ----belmond,WI 608-762-5517 Good guy to deal with, makes good product for a reasonaqble price, when he says it will shipped.
Dealing with Denny's carb can be tough.
