FARMALL BLOCK
TOWBOATT
05-30-2006 12:12:41
WILL FARMALL SUPER M CYL KITS FIT IN A FARMALL M BLOCK WITH OUT BORING BLOCK?
JMS1066
05-31-2006 12:41:04
 Re: FARMALL BLOCK in reply to TOWBOATT, 05-30-2006 12:12:41
WHY DOES IT MATTER WHAT THE NUMBER IS ON THE BLOCK? WHAT IS THE DIFFRENCES
newpuller
05-31-2006 14:57:47
 Re: FARMALL BLOCK in reply to JMS1066, 05-31-2006 12:41:04
I was just wondering about the cast number. Some say that the 6943 block is the better block because it weighs more, has more cast iron in it. It was also used in the SM, IDB.
jms1066
05-31-2006 15:21:15
 Re: FARMALL BLOCK in reply to newpuller, 05-31-2006 14:57:47
ok thanks i didnt know that
newpuller
05-30-2006 12:28:01
NO. You can however get a 4" over bore kit for your M. If you want the 4 1/8" pistons you have to machine the cylinders in your block. If you are removing the crank you have to pull the engine out of the tractor anyway, so you might want to think about putting the 4 1/8" kit in. I'm having my block machined to take the 4 1/8" piston. What is the cast number of your Ms engine? is it a 6722 or a 6943?
