FullPullH or any other GVATC member
Kevin
05-27-2006 13:41:06
Pull tommorow in fillmore, right? Start time 11am? Is it going to be like the test pull with the gates opening at 8 and scales by 9? Thanks for the help, my massey is ready to roll out the drive way by 6:30 am tommorow and if the scales wont be open till 11 id like to find out so i dont sit there doing nothing for hours.
AW Puller
05-27-2006 16:59:45
 Re: FullPullH or any other GVATC member in reply to Kevin, 05-27-2006 13:41:06
What is so hard about weighing a tractor that you have to get there the minute the scales open? I have never understood why people will weigh their tractor a dozen times before the pull even starts.
Kevin
05-27-2006 17:25:23
 Re: FullPullH or any other GVATC member in reply to AW Puller, 05-27-2006 16:59:45
Well i have absolutley no clue what my tractor weighs to start with becuase i done alot of stripping over the window and id like to find out exactly what weights i need to put on for the 4 classes im running. Its the first pull of the year, otherwise i only weigh it when necasary but i would certainly like an idea were i stand for weights before it all starts.
Full Pull H
05-27-2006 17:46:47
 Re: FullPullH or any other GVATC member in reply to Kevin, 05-27-2006 17:25:23
Yes the scales should open around 9:00 but be patient please. Being no test pull there maybe a little bugs to work out.
Kevin
05-27-2006 17:52:34
 Re: FullPullH or any other GVATC member in reply to Full Pull H, 05-27-2006 17:46:47
If i get the around 8am will i be the only one there? Im bringing a grill and cooking breakfeast if that helps out.
kevin
05-27-2006 18:00:04
 Re: FullPullH or any other GVATC member in reply to Kevin, 05-27-2006 17:52:34
I really just wanna leave early just in case i get lost trying to find it. Just wanna make sure i wont bother anyone if i do find it easily and get the by 8. By any chance does anyone have an adress of a place nearby just in case i get really lost i could just put it in the gps?
