Need front wheels for MM GB
Texas Red1
05-27-2006 08:35:12
I need some help. I need to get some wheels on the MM GB so i can load it. Are the front rems on a UTS the same as a GB. If the bolt pattern is the same i can use the ones on my uts to get it loaded. thanks for the help TR
Mopower
05-29-2006 19:15:45
 Re: Need front wheels for MM GB in reply to Texas Red1, 05-27-2006 08:35:12
It's the same six bolt pattern unless your UTS is like a 1947 or earlier. Some Us used a small six bolt pattern in the early-mid forties. 95% sure you will have the same pattern.
Texas Red1
05-30-2006 03:08:06
 Re: Need front wheels for MM GB in reply to Mopower, 05-29-2006 19:15:45
Thank you for the help. the tractor is several miles from me and no rubber on. need to get some tires on if ,so i can load it. TR
