More power for MM UTS
Texas Red1
05-26-2006 17:33:12
I had to change my name to get back in to post, what is going on with that??
Now my question: I am going to put a GB crank, cam, blocks, and 4210 heads into my uts, some of the info i see, said that the comp ratio would 9 to 1. is this right. Do i use the GB cam of do i need to have reground? What kind of horse power will i see? going to put new rings and new valve job in it also. i will be changing the 30 inch tires to 18.5 x 34s I guess what i need to know is there anything i need to get it right? Thanks for the help TR
Mopower
05-29-2006 19:20:51
 Re: More power for MM UTS in reply to Texas Red1, 05-26-2006 17:33:12
This is a good simple combo. A GB cam will work fine but for the extra little dollar, you should have it reground at Berry Cam Service (no relation). With a mild puller cam and maybe an overbore, you should have 90 horsepower or so depending on RPM. We are doing this to a UB and are hoping to break 100 horses with it.
Ethan Berry
Texas Red1
05-30-2006 03:13:35
 Re: More power for MM UTS in reply to Mopower, 05-29-2006 19:20:51
I had read a lot of post about doing this and the other i came across this GB and was able to get it for scrap price. it ran when he parked it. ( bosted a rear tire) It has a good muffler with weather cap and the oil looks good. motor is stuck right now, but i hope it will come loos easy. It is on LP right now. thanks again . TR
