M with a turbo?
Tim Shultz
05-25-2006 15:45:49
hello, first time to post on this forum...
got a question for you all.. a buddy of mine just got a farmall M.. in a few weeks he is going to make it into a super M.. and I had seen a picture of an M in the tractor photos awhile back that had a turbo on it.. any specs or anything else on that? good idea or no? is a turbo on a gas point-less? he don't want it for pulling, just would like to give it some balls. lol
Tim Shultz
Turbos10
05-25-2006 20:36:22
 Re: M with a turbo? in reply to Tim Shultz, 05-25-2006 15:45:49
Hehe...that would be me ;).
I just finished mine up and, no, it is certainly not pointless. Now, putting a turbo on and using the factory carb and manifolding like the one in the photo album would be less productive, but it is still not pointless IMO. I ditched the governor and updraft for a electronic rev limiter and a Holley carb, but for a farm tractor that does not make much sense. Mine is for pulling and all I need is a few seconds in 4th gear so bouncing off the rev limiter is not big deal.
If I were doing one for an updraft and trying to use the governor, I would certainly get a larger carb. You will also want to keep in mind that you need to boost reference the fuel pressure supply in some way. This could be using a fuel pump and regulator like I did, or in a factory setup I guess you could boost reference the tank. This is necessary because if you dont, when boost=fuel pressure fuel flow=0. An EFI pump, 4309 Mallory FPR, and a 350cfm Holley are working well for me so far.
You will also want to keep the turbo small. Dont be temped to throw a large one on it, cause it will not work. I am using a 50 trim Garrett TO335 and it is a perfect match to the engine.
I can talk all day about this, so if you want to know anything else, just ask.
JasonM
05-26-2006 09:55:10
 Re: M with a turbo? in reply to Turbos10, 05-25-2006 20:36:22
IS the carb on the inlet side of the turbo or the outlet? I have a little Allis I was thinking of doing this with. How much boost are you getting?
turbos10
05-26-2006 16:11:09
 Re: M with a turbo? in reply to JasonM, 05-26-2006 09:55:10
I have the carb on the discharge side. It is by far the best configuration for power and responce. Plus, you can use a much smaller carb. I am only running 8psi right now, but I plan to work up as close to 30 as I can. I will go up slowly and just see how it goes.
Chris
Don L C
05-25-2006 19:07:39
A few days ago a fella on the IHS FARMALL forem or the TRACTOR forem wasjust finishing up with a turbo..... .I think his handle was Turbo 10....
