boring a block
frank in PDL
05-21-2006 10:21:11
How much can you bore out a block for a Model A John Deere? the reason I am asking is when I had to rebuild the block on my Model A I wanted to use the original pistons, so I got someone the bore out the block and insert sleeves so I could. Now one of the sleeves has moved causing problems with the tractor. What I wanted to do was to bore the block where I did not have to use sleeves again. I belive the sleeves are 100 tho.
Thanks in advance
Frank in PDL
skip 33652
05-21-2006 11:04:24
 Re: boring a block in reply to frank in PDL, 05-21-2006 10:21:11
almost all of the JD A blocks will take .250" overbore some are running .375" overbore and I have one that is rusted through on the standard bore.So without doing some checking and or sonic testing it is tough to say how much they will take. Paul
