Oil for Pulling Tractor Engine
jhb
05-18-2006 02:19:27
Is 10W30 adequate for a 165 pound compression engine standard to 10%+ rpm? What do you use and what determines the weight to use. Some I know use nothing but a 15W40. Wondering if may be too heavy for proper ring and cylinder wall lubrication. What do you think?
piston
05-18-2006 06:29:06
 Re: Oil for Pulling Tractor Engine in reply to jhb, 05-18-2006 02:19:27
sorry i didnot read down far enough, looking for stock pull with a 165 lb. compression engine, yes sir a truth tractor puller
rtm
05-18-2006 06:02:23
I use shell rotela 15w40 in my 6.0 ford truck and 6 cyl tractor but if your your motor is broke in i would put synthedic in 5w40 buy shell would be a good choice
