hardblock cooling ?
HOT PULLER
05-17-2006 10:29:12
I have a block filled to top water in head only.Probably not the ideal setup.What are everyone using for acirculation pump size supply lines etc.?Currently 1.5 gpm rv water pump three eighths hoses not enough.Its a Farmall M by the way.Thanks for all replys.
jd b puller
05-18-2006 16:17:31
 Re: hardblock cooling ? in reply to HOT PULLER, 05-17-2006 10:29:12
I"ve got a BBC aluminum pump w/electric drive kit on it. Looks kinda hoakie right now, but once the side shields are on it, you won"t see it.
all so a m
05-17-2006 14:47:46
school bus water pump
JDGnut
05-17-2006 15:49:52
 Re: hardblock cooling ? in reply to all so a m, 05-17-2006 14:47:46
Try a Furflow AquaTiger...
