tire pressure
kwf
05-17-2006 04:21:28
Is there a general rule of thumb for tire pressure for soft verses hard track or a certain amount of psi per tractor weight that works well? For example 1 or 1.5 psi per 1000 lbs the tractor weighs.
D boll
05-17-2006 12:22:40
 Re: tire pressure in reply to kwf, 05-17-2006 04:21:28
I have had the best luck in 4500 to 6500 at 9.5 to 10 psi with a 15.5x38 Firestone f&r
Dave in MN
05-17-2006 18:59:08
 Re: tire pressure in reply to D boll, 05-17-2006 12:22:40
brand of tire, model of tire, type of rubber, age of tire, size of tire, weight of class, type of wear on tire (sharp edges, road worn, rounded bars),type of dirt, clay on track. How much moisture on track, even how the track is graded from the last puller ahead of you. It even makes a differance in the type/accuracy in the tire guage you use. Even the length/height of hitch.
That's why if you lose by an inch you can tell yourself "if only I had...."
