rims
Little Yellow D
05-13-2006 19:22:52
Looking for advice. Has anyone cut centers out of dual rims and re-welded them in place? on 18 in rims would i want the center flange at 9 in? there J D rims w/9hole. will take any help. Thanks, Mike.
DSK
05-13-2006 20:29:36
 Re: rims in reply to Little Yellow Dude, 05-13-2006 19:22:52
I have done this to a few sets of rims. It's not too bad a job depending on what style wheel you have. If they are factory JD wheels, the centers are usually just arc welded to the rim, just use a cut-off wheel in a 4 inch grinder to split the welds, and pound the center out with a sledge hammer. Grind off the remaining weld and weld back in where you want them...these are the easy ones. Some of the older dual rims such as those from M&W had the centers attached with 2 or more large spot welds. Unless some one else knows a better way, I use a cutting torch and carefully cut around the spot weld to free the center from the rim,you'll spend a lot of time with the grinder removing the remaining spotweld, but they can be made to look good, it just takes more time. I see Miller Tire is now offering new 9 bolt centers and rims available seperately, but you can save some $$$ by redoing the old ones.
