stroker rods?
stroker ace
05-13-2006 05:27:34
dumb question? If you stroke a crank can you use stock rods or do you use shorter rods and they have to be custom built?
jd b puller
05-15-2006 05:03:41
 Re: stroker rods? in reply to stroker ace, 05-13-2006 05:27:34
Normally, when you stroke the crank, due to the time, money and pain in the a$$ of doing all this, you go for broke. Sometimes that"s what you get as well... A lot of guys will actually make the rod journals smaller (more room in the crankcase), so your stock rods won"t work. Also, the rods in your tractor are designed for your crankcase. If you go making the crank bigger, the rods will likely not fit. So you either make your own rods - or build some out of 2...
PGpower
05-13-2006 05:54:21
if you stroke a crank, something has to change. Just as an example: if you stroke your crank 1", then the piston will now be sticking up .5" past the block with everything else stock. You have to either shorten the rod, change the piston pin location, or raise the height of the block. thousands of ways to compensate for the .5", but something has to change.
Bryce
05-13-2006 09:39:06
 Re: stroker rods? in reply to PGpower, 05-13-2006 05:54:21
Yes something HAS to change BUT depending on how far you stroke you can still use stock rods.I have gone 1.5" using stock rods.
Bryce
05-13-2006 05:29:39
Depends on how far you go on the stroke.
