Tips for A john deere
KMSD
05-12-2006 20:02:31
Would like to build my 1943 A john deere into a puller...I have not the slightest clue...What to do...Would like to know how i should go about building the engine etc. etc...I know some of you guys pull them old As tell me what you got cookin
DSK
05-13-2006 13:11:36
 Re: Tips for A john deere in reply to KMSD , 05-12-2006 20:02:31
Like the other guys said, set up the tractor with weight brackets and tip bars and start pulling. Don't be concerned about $20 trophys for awhile, you will learn as you go. I've been pulling antiques for 22 years and one thing I've learned is you don't need to take a second mortgage to do well and have fun in local competition. Talk to experienced pullers, most will be willing to share their knowledge. Stay away from the loudmouths and those which badmouth competitive makes. I always view this sport as a schoolboys' argument that has been carried into adulthood, so pull the color you prefer and have fun with it. If it's something that you enjoy, your tractor will evolve into a more competitive machine as you can afford to feed more money into it. A 43 A is a very good choice as a puller, lots of parts available at reasonable prices, and can be made a competive Div. 3 4500-5500 tractor.
Jeff Oliver
05-13-2006 05:14:04
Depends on what kind of puller you are wanting to build. If your wanting a Farm Stock puller then a good valve job, high compression pistons or a Power Block is about all you will needmotor wise. Make sure your hitch is good and put wheelie bars on it. Then work on a good set of tires ( not new ones but good worn ones) and start pulling to figure out where to put your weights. Try to make sure you keep the front end on the ground or at least just barely tipping it. If your wanting to build a competitive Open tractor get your checkbook out cause there is alot to doing that.Stroking,boring,cam,all kinds of stuff.
If your just getting started just get your A tuned up good put a hitch, wheelie bars, andwirght brackets on and go have some fun. Best way to leaern is to get out there, but the emphasis here is FUN!!!! If you win great!!! If you don't chalk it up to experience for a while. Watch what some of the vetern pullers do and ask questions.
BushogPapa
05-12-2006 21:45:26
Except for high compression pistons and a good valve job, just go and have FUN..!! There are fellas out there with More $$$ in their tractors than your house cost...!! The "Late Styled A" has a slow "creeper gear" and with them, you have all the power you need... Same for the "Late Styled B".. Save the money and go to School...!!!
Ron..
Lamont
05-12-2006 20:53:32
Use the money it would take to make a good puller out of it and build 4 better ones of other brands. :)
B BARENIE
05-12-2006 20:33:15
SCRAP PRICE IS UP !
