Losing HP
stock?
05-08-2006 14:52:12
I pull with a club that has H.P. limits in the stock classes. what the best way to loose 5/10 horse and not hurt the tractor? Tractor must turn atleast factory RPM's and dyno at 540 pto. thanks in advance!!!
cowboy red
05-10-2006 05:58:42
 Re: Losing HP in reply to stock?, 05-08-2006 14:52:12
you can turn in your fuel some too. but if you have a higher compression dont turn it in too much and watch your temp guage. the leaner you are the hotter your eninge.
JD hauler
05-09-2006 18:41:25
stop cheating, pull div 2, LOL.
J2
05-09-2006 06:49:38
Use a restrictor plate after the carb... or a stop to limit the throttle plate... keeps all of the low end torque... J2
cantcatchme
05-08-2006 19:56:00
hook a ground wire to one cylinder the other end to a toggle switch.Leave it off when you pull,flip the switch when they dyno you.Cuts you back to 3 cyl.:))
LOOSER
05-08-2006 15:24:29
Back off on your timing
