MW dyno questions
Andy
03-27-2002 21:32:42
Just got an older M&W dyno. It's a smaller one 90 or 95 hp. I was wondering what kind of fluid to put in it,(it's been drained) thanks
Mike Aylward
03-28-2002 19:27:26
 Re: MW dyno questions in reply to Andy, 03-27-2002 21:32:42
Andy, I used to own a dyno similar to yours and the book on it said to use hydraulic oil. Like the other post said, be sure the coils will not leak before filling with oil, and also be sure to cover the coils with oil to keep condensation off of them. Hope this helps. Mike
Troy
03-28-2002 06:09:04
10 weight non detergent. If you don't use non detergent it will foam and then you could have problems.
Jack
03-28-2002 05:07:23
On our 100 hp M&W the owners manual says straight 10 weight oil.Hope this helps.Jack(TN).
Rich
03-28-2002 05:01:58
Andy,
Where are you located? I have been looking to run my Oliver 77 on a dyno.
Thanks
Rich
bigmotors
03-27-2002 22:21:31
Use Hydraulic Oil. You might want to run water threw it first, to see if you have any leaks in your copper tubes.
Good Luck.
