need opinion
pdm00
05-03-2006 15:48:33
I've got a 450 Farmall that just spun a rod bearing. What would be a good way to get a few more ponies out of it without mortgaging the farm. It can't run wild because it augers about 40,000 bushels of corn a year and needs to last. Would be nice to have a little more power to turn the 10" by 66' auger. Thanks in advance.
SUPER MTA PULLER
05-04-2006 11:12:15
 Re: need opinion in reply to pdm00, 05-03-2006 15:48:33
Since you have to grind the crank anyway why not offset grind tothe small M bearing? thenmill off the amount of piston protrusion from the piston deck ie the flat part leaving the dome untouched.Should give you about a quarter inch stroker and eighth more dome height.I may have the numbers wrong but it willstill work and be as cheap as you can get .
ChadS
05-03-2006 15:58:25
Read the post below about the M farmall,, anything you need to know is in that post, or, I can retype it here,, if you need more info from that, let us know! ChadS
