MM G 705
dogonewild
05-02-2006 13:06:28
I have a 504 in a G705lp with 4206 heads and ensign carb/convertor. Im gonna pull it with the stock cubes(cause my wallet wount handel it right now!) this season. Is my setup worth foolin with or is there a different carb/convertor/intake setup that will perform better? Is the heads OK or not? New to the Molines and all suggestions and opinions are welcome. Need all the help I can get. Thanks
turbo705
05-03-2006 07:00:34
 Re: MM G 705 in reply to dogonewild, 05-02-2006 13:06:28
It really depends on your competition. I pulled my 705 with a 504 diesel that had and untouched motor except for the injection pump and injectors. I ran it in an open class all summer and I was pleased with how it did. I was beat several times but for an untouched motor right out of the field I was happy with the results. In my opinon your lp should run better than a diesel any day. I'm not sure which intake you have but I know you can bet a much bigger moline intake to start with.
