Mods and Limits of an M??.....kindof long....
Turbos10
04-26-2006 19:37:30
Hey all,
I have a little project that I am about to start and I would love some input from you guys. I am totally new to pulling, but completely experienced in gasoline engine mods. I am going to try to apply some of my car experience to a tractor since there is a new local class starting up with the antique pullers.
I am planning on running a blow through turbo setup to start. I already have a custom EFI/Turbo engine under by belt so this is gravy. What I need to know is how well the M will hold up in stock fashion, and what problems I might run into. Please let me know if the plan has major flaws.
I am planning on either mechanically limiting timing or switching to an MSD BTM for tunable boost spark control. I will likely be eliminating the governor and going with a Holley carb and soft touch rev limiting on the ignition instead. I will be running low boost and race fuel initially untill I see how it works out. The next plan is to move up boost and add water injection for detonation control.
I guess what I need to know is how well you guys think a stock M long block will hold up, and where I need to limit the RPM. There is a local guy doing this with alcohol and spinning about 5kRPM at 30psi of boost. However, his engine is balanced with light automotive pistons and rods. What I am hoping is that I can run about 2.5-3k RPM and get it to hang together a little while till I can get another long block together.....sortof a bomb tuning block so to speak;).
Lemme know what you guys think...
Ian Johnsen
04-27-2006 22:08:38
 Re: Mods and Limits of an M??.....kindof long.... in reply to Turbos10, 04-26-2006 19:37:30
I have a modified turbo tractor that I run in our Hot farm class. But, our club requires us to run our governor, stock throttle linkage, and a 3500 rpm limit. My manifold is stock. I mounted the turbo and wastegate to the pipe threaded into the top of the manifold. I converted the tractor from gas to propane. Propane works great for a blow through application. The carb is set up for a pressurized system (no blow by at the throttle shaft and no floats to crush under boost or building a pressure box). Fuel enrichment under boost is solved by a balance tube from the boost pipe to the propane converter/regulator. If you have rpm restrictions, the key is to find the right exhaust housing small enough to create boost at lower rpms.
Turbos10
05-02-2006 16:45:20
 Re: Mods and Limits of an M??.....kindof long.... in reply to Ian Johnsen, 04-27-2006 22:08:38
Not sure what happened to my other reply....
Ian,
What kind of mods did you do to the internals of your engine. I am very curious on what it takes to make the engine turn 3500 RPM comfortably. That would just make my day if you are running factory internals :D.
I am planning to ditch the govenor for now. I guess a scatter blanket would be a good idea around the bell housing. I am planning to put a little cage if things start getting fast. There are a bunch of guys in the V8 class with cages and bracing so if the tractor breaks in half or scatters a diff. or trans. it will not come and get them. It is well worth a couple days work to stay safe.
D boll
04-27-2006 08:41:51
If your friend is running a cast flywheel he might want to read my post on excessive rpm's and clutch/flywheel explosions!
