MAnifold and Carb guestion
Shaggy
04-25-2006 21:58:24
What I have is a Farmall Super C with the C-153 combine engine. What I am wanting to know is can I run the carb from the combine on it legally or do I have to run the carb that goes with the SC? The manifold I have can be worked over so it can work with the bigger combine carb.
Thanks Shaggy
Shaggy
04-26-2006 06:49:41
 Re: MAnifold and Carb guestion in reply to Shaggy, 04-25-2006 21:58:24
What I have done is take the cut intake section off the combine manifold and cut the intake section off the 230 manifold and cleaned things up and it bolts on and looks factory other than the bigger Zenith carb. It has about a 2 in inlet.
Shaggy
Flogger
04-26-2006 10:10:51
 Re: MAnifold and Carb guestion in reply to Shaggy, 04-26-2006 06:49:41
Most associations say if it's an agricultural carb (Like a combine...) it's okay. Go for it.
Shaggy
04-26-2006 11:50:10
 Re: MAnifold and Carb guestion in reply to Flogger, 04-26-2006 10:10:51
The cool part is that I should be able to take off the middle 4 nuts and switch it back if needed. I just wanted some input from others before I cut on the other manifold.
Flogger
04-26-2006 14:32:43
 Re: MAnifold and Carb guestion in reply to Shaggy, 04-26-2006 11:50:10
'Heard of at least one puller who tried to sneak in an airplane carb... Said it was off a crop duster... Maybe it was.
