Reccomendations on a starter for B jd
oskpuller
04-25-2006 20:07:10
Looking for somthing that will turn it over easy,I have heard of bob cat starters and others need help in this area of starters.
WTW
04-26-2006 06:40:19
 Re: Reccomendations on a starter for B jd in reply to oskpuller, 04-25-2006 20:07:10
On our pulling tractors (unstyled B John Deere's) I use a Delco brand starter that is made in Japan and is used on B series Cummins Diesel engines. This starter is a small motor, 12 volt, gear reduction unit in a light weight aluminum case that has starter solenoid is positioned on it at the proper angle of starter nose opening so when mounted to original B John Deere starter bracket solenoid will not interfere with steering post (solenoid is almost straight up). There is many different starters used on these same series engines for many different applications so you will have to be sure you are getting the right one. There are many that look just like it but will have solenoid at a different position/angle and they will interfere with steering post or governor case on a B. I do not have any numbers handy right now. Correct starter will bolt on without any modification but after breaking off a couple of starter brackets and reinforcing them I have not had any problems now for several years. Starter was not the reason brackets failed it was the compression and power it takes to roll it over. Once the magneto decided to fire without impulse causing engine to fire with timing advanced and engine kick back broke starter and bracket. So if you have some considerable amount of compression plan on reinforcing your starter bracket. I priced this starter from Cummins and you do not want to buy it there. Go to a good starter shop and buy it, if you are like me you will buy it for half of what Cummins wanted for it. Cummins wanted around $600.00 plus core charge. Good Luck DW
oskpuller
04-26-2006 12:14:57
 Re: Reccomendations on a starter for B jd in reply to WTW, 04-26-2006 06:40:19
thanks for you responce, and info
