How Light on a oliver 66
Larrys2
04-25-2006 19:55:20
Can I get A 66 oliver nf. into 2500 class? If so, what do i have to do? Thanks Larry..... .
Lee W
04-27-2006 10:24:22
 Re: How Light on a oliver 66 in reply to Larrys2, 04-25-2006 19:55:20
I know of two that pull in the 2500 lb class,it takes a lot of work to get one there. They use a smaller Rad, cut off the axles and the casting that holds the fenders on. They use a garden tractor gas tank and I think one of them had allumin front hubs.
new kid in town
04-26-2006 18:43:19
been as light as 2750. know of others that light. also know more that want to know how we got there.most are at 3000 or 3250.
questions
04-27-2006 05:54:24
 Re: How Light on a oliver 66 in reply to new kid in town, 04-26-2006 18:43:19
new kid,why don't you share the info? Oh ,you must have all Top Secret stuff?
new kid in town
04-27-2006 19:50:02
 Re: How Light on a oliver 66 in reply to questions, 04-27-2006 05:54:24
it"s part of the sport. besides, if you didn"t build it yourself you are really only renting it!
johndear
04-25-2006 20:15:57
We have an oliver 60 that weighs 2500 with a 200 lb driver. Nothing removed. Just stamped steel 9 bolt rears. I think a 66 has a little heavier motor so you might have to hunt up some thin or light weight rear wheels with as light a tires as you can find with the tread gone. Should be real close. Could remove fenders and save 25 lb or so if organization allows. Tractors are built light, not much to loose.
